Windows compatibility
monkeygirl365
Post by monkeygirl365 »
i was so drawn in with this whole site and the wonderful things people have been saying....LOVE IT! then...i saw where the Windows compatibility with kJams is kind of a work in progress :-/ is this still the case? if so, what system do you recommend for someone with Windows to run a show without dealing with the kinks of the Windows capability issues with kjams (if they still exist)? thanks :-)
Re: Windows compatibility
no, actually windows is just about done, i should remove that message.
you should have a RECENT PC. i recommend windows 7 or 8, with 8 gigs of ram or more. quad CPU or more.
monkeygirl365
thanks for the quick response! i got the windows 7 part covered, but does it matter if i have vista?
vista is pretty old by now, but it should be okay.
