Itunes Integration
Phil Derbyshire
Itunes Integration
Post by Phil Derbyshire »
Anybody know how to get itunes library into Kjams?
Re: Itunes Integration
Dunno why you'd wanna do that, but, you can add the music to kJams in the same way that you add karaoke tracks. As far as I know there's no way to integrate iTunes and kJams
Phil Derbyshire
Hi Len
It's Phil, I spoke with you last week on the phone. I was reading something by Dave that Itunes can integrate with Kjams so that Kjams runs both music and Karaoke all in the same programme. I just thought it may be helpful, maybe not.
It's the crossfader that Dave's talking about.
It's here
https://karaoke.kjams.com/wiki/Code/new ... Crossfader
Phil Derbyshire
I have the crossfader but I don't think it is ideal. I believe having music and karaoke in the same programme would be more user friendly.
It may be more user friendly but then you will not be able to crossfade.
if you really want to add your iTunes music to kjams (i recommend against it) then just add the iTunes Library folder to kjams.
Phil Derbyshire
Ok point taken..
