Perian plug in
chrisepowers
Perian plug in
Hi sorry if I come across like a noob but I am . I downloaded the trial and have every intention of purchasing pro one i learn the program fully. Here is an issue I am having .. I am on a early 2008 macbook btw. when i select a song from the library it says you need the perian plug in installed. I installed it..but I still get that message on almost every song i try and play..some songs I can cancel the message and play anyways , and some wont play at all. Do i need to do something else in settings? Thank you.
Re: Perian plug in
are you sure you're on the latest version?
try the rogue version.
chrisepowers
Re: Perian plug in
Dave I uninstalled and reinstalled the lastest version I am still getting a message saying I need perian plug in..most songs will play..some wont..but as far as the rouge version..I have tried for 2 days no and the link takes me to a "we cant find your page". I really want this to work as I am going to start working some bars.
chrisepowers
Re: Perian plug in
Hmm dont know if this has anything to do with it but when i closed out kjams window i noticed VLC window was playing the file..maybe thats whats happening..is there a way in settings to make sure its using quicktime?
Re: Perian plug in
i think we should get on the fone
are you available sunday night after 7pm pacific time? or monday morning?
chrisepowers
Re: Perian plug in
yes call anytime 702 578 1436 Chris
Re: Perian plug in
sorry, but can you please call me?
mu number is on this page:
Re: Perian plug in
I have the same problem, If ya'll get this sorted out let me know . I'll watch this topic.
Re: Perian plug in
someone with this problem please call me during office hours, else it won't get fixed (i am not having the problem so i HAVE to see your computer)
sparky1034
Re: Perian plug in
I get this now on more than half the songs I try to play. I download it and install it and no change???? Not sure but I got a karaoke gig coming up so hopefully we can fix this.
Re: Perian plug in
as i said: someone with this problem needs to CALL ME
