Urrgh....Heeeelp!!!
floradora
Urrgh....Heeeelp!!!
Post by floradora »
I'm running KJams Lite on MacBook Pro OS Lion. On opening the program tonight, it asked me if I wanted to upgrade to the latest version. As I'm going to be using it at the weekend for a friend's party, I said not yet, as I'm nervous of changing anything at a crucial time. I don't know what happened next, because the top menu bar and the dock icons have now disappeared when KJams is active on screen, which means I can't close it down. I'm hopeful that if I could close the program, then re-open it, everything would be OK again. Any ideas?
Re: Urrgh....Heeeelp!!!
you're in full screen mode, and this is not related to updating or declining to update.
command-zero will get you out
floradora
Post by floradora »
Phew! Thanks so much, Dave. Everything's back to normal. Now I feel stupid for having panicked.
floradora
Post by floradora »
My first outing with KJams was perfect, great, awesome etc etc. None of those frustrating glitches I used to get when running free karaoke software on a PC. Best software purchase I ever made :P
awesome!
