KJams throwing out Font and Placement Data from Tuneprompter
Politaoke
Post by Politaoke »
HI Dave,
It looks like all the new tuneprompter files I make and import to the latest KJams lose all the font and placement data. Instead of being centered on the screen, they move to the top. It doesn't look so great. Any suggestion of what I should do?
Best,
Diana from Politaoke~!
You for Office.
<a>www.politaoke.com</a>
Re: KJams throwing out Font and Placement Data from Tuneprom
are you sure you've got the latest kJams? when i make a new TP file, it looks perfectly centered (vertically).
did you accidentally set the "defaults" in the "Get Media Info" dialog? you do that by holding the option key when pressing OK.
gaalati
Post by gaalati »
The same problem for me. I have the latest kJams. I can't find Get Medig Info dialog.
import a ktp file (not a movie MADE from a ktp file), then select that new song and pick "Get Media Info" from the File menu. Set it to what you want to be defaults, then option click the OK button.
gaalati
Post by gaalati »
Thank you very much for your fast response! It works!
:D
