Drag n Drop alternative
xandra
Post by xandra »
Unless I've missed something, several actions are only doable by dragging a song somewhere (for example adding to a Singer's playlist)
For some reason this works pretty funky for me (often the song begins to play before I can drag it somewhere - or won't budge at all) Would be real nice if there were a menu item - (contextual menu item) and or keyboard command for all actions.
xandra
there are alternatives
to add to a singer:
right click->add to singer->singer
also you should know about target mode.
ps: the not budging is a bug i plan to fix like immediately
