Stuck saving database on deletes
Razor
Post by Razor »
Steps are as follows:
1) Activity window shows pull meta activties or push meta activities in background
2) A few songs are deleted from the database using delete key (references only)
3) It takes a very long time for delete to complete or a force quit
Using external USB drive. Is it getting stuck due to disk IO/read/write operations?
Re: Stuck saving database on deletes
i recommend you wait until all push/pull tasks complete before you do anything else.
also: use firewire800 or thunderbolt, cuz USB is terrible.
