Moving KJams Lite from Desktop Mac to Macbook Pro
powermixx
Post by powermixx »
What folders do I need to copy to my Macbook Pro? I moved my music to an external hard drive. I then changed the "Prefs|Advanced" folder location - on both Macs. When I open KJams Lite on the Macbook, no tunes :(
So I did some more digging. I see these other folders:
/users/%username%/Library/Preferences/kJams/
/Library/Application Support/kJams/
I also copied those folders from the desktop mac to the Macbook...still nothing - when I launch the app on the MBP, no tunes.
moving
there is a section in the wiki regarding moving, click here.
basically the part you forgot was pointing your user kJams to the external library with an alias.
powermixx
Post by powermixx »
That link helped, much thanks!
yaay!
