Screen Display errors
seanphafer
Post by seanphafer »
I'm on a 13" macbook Pro with 10.7.3 and running the latest kJams. I've been getting graphic display bugs over in the Source Pane side of the app. I'll get multiple icons of the face icon running up and down the left side of the screen. If i close a rollout they'll vanish, but once I scroll again they show up.
Re: Screen Display errors
thanks, yes i see it, i'll fix it soon.
seanphafer
Great, thanks!
seanphafer
I just downloaded the latest version, and while some of the errors have vanished, I'm still getting the face icons and playlist/note icons ghosting in the top bar, and bottom bar of the Source pane.
screen shot that, please, include the version number of kjams too
d52r38
hahahah! lol, okay i have to make my window taller! great thanks!
FYI, they pop up when you drag a singer.
and ONLY then?
As far as I have seen, yes.
it is fixed in the current release
seanphafer
I just downloaded the latest update and I am still getting them. It's just when sculling, and it's just the Icons, not text. They also appear to the left in the grey side bar if you scroll left/right.
define "sculling" ?
are you SURE you're on r40? if so, please list specific steps to reproduce the bug. every step.
seanphafer
Sorry, I meant scrolling. It's always there when I scroll the side column. See attached.
ah! very well. i'll try to reproduce that!
Later: Fixed!
