Background/Idle playlist
DJMatt
Post by DJMatt »
Hi,
Currently I've got a singer called "-", I then assign my background video playlist to this singer. This works well, to an extent. If it gets busy enough that I just want singers full time on the Rotation I can just mark "-" as being not here.
None this less, it feels like a bit of a kludge, does anyone have a more elegant solution?
Re: Background/Idle playlist
there is no elegant way at the moment
but you might try using iTunes for background videos, and use the auto-crossfader, and the "hide video window when paused" feature (make the iTunes videos full screen UNDER kjams, then when kjams hides, the itunes window will be showing)
http://karaoke.kjams.com/wiki/Code/new_ ... Crossfader
