Couple of Bugs : related to stores
nite
Post by nite »
Last night at a venue their internet access was out. I noticed that the option to include stores in the library was set to on. When a user picked a song that had to be downloaded it would freeze up kjams. Seemed like the timeout wasn't being set. I'm sure it thought I was on the network since I did have an ip from the router but the actual access out to the internet from the router was out.
After realizing the issue was the online streams were included in the store I attempted to change the option to not include them. This gave me the pop up that the setting would be active on restart of kjams. That cause an infinite loop of this pop up confirmation. Looks like after clicking ok it would try to put the check mark back in the option, causing the confirmation pop again. There was no way out of this loop. I eventually went into the top secret config files and just changed it to false for the include store option. This infinite loop would also occur is I just unchecked the store name that was included in the library.
Re: Couple of Bugs : related to stores
mac or windows?
what version of kJams? latest?
if not latest, remember don't report a problem unless it's in the latest version of kJams.
i am unable to reproduce this problem.
nite
Post by nite »
I'll double check tonight when I have my laptop in front of me. I did an update the on Sunday and did the gig last night. I'm assuming it's the latest build.
mac
or
windows
nite
Post by nite »
Mac.. and I suck cause I didn't have time to verify the release for you.
no worries, let me know what you find.
nite
Post by nite »
I was using 1.0d52r29
Sorry for the late response, holidays and stuff you know.
I just noticed a new update, I'll do that and let you know if the issue still exists
nite
Post by nite »
Looks to be fixed in the new release r30
