Pull Meta Data from Media Rage and The Tagger not working
Pedro
Post by Pedro »
Hi,
I used Media Rage and "The Tagger" to clean up my ID3 tags and when I add the songs to the library the meta data is not pulled into kJams. iTunes, Preview, and others can pull the information, and display it correctly.
I tried versions 1.0d52r29 and 1.0d52r30 and had the same behavior. I this a known bug? Is there a work around?
Pedro
Re: Pull Meta Data from Media Rage and The Tagger not workin
Post by Pedro »
found the reason why ... The Tagger and Media Rage do not write UTF8 encoded tags, and kJams does not pick up the encoding used by them. Using http://code.google.com/p/mp3-tag-iconv/ i was able to convert all the tags to UTF8 and it worked, kJams was able to pull the meat data from the files.
Anyway I still fill that that this is a bug that needs to be solved to make kJams more robust.
kJams can read UTF8 and non-utf8 tags.
i just tried media rage and it worked perfectly. perhaps you could send me a sample mp3 file that has tags that kJams does not read?
are you on mac or windows? what version of media rage do you have?
Pedro
Post by Pedro »
On a Mac 10.6.8
i need you to answer the other question too.
please send me a sample song that works in media rage but not kJams.
