Exception during import
tracyterrell
Post by tracyterrell »
Dave I'm getting an exception message during import.
I'm running Lion, KJams 1.0d52r28.
I'm rebuilding by KJams database after moving all of my .zip files to a new external drive. I renamed the /music/kjams to /music/kjamsold then restarted KJams. It created a new /music/kjams folder, downloaded the music stores, etc. with no problem. Then I went to Import a folder of .zip files (about 1,400) from the new external drive. It seemed to me that the exception occurred when KJams started trying to get the metadata. The process DID complete successfully after I clicked OK on a couple of these exception messages (SEE ATTACHED SCREEN PRINT).
Love the meta data feature - is that new? Should save a bunch of work re-interpreting names....
Tracy
Re: Exception during import
yeah, sort by PLI before you add to library. it's a minor bug.
tracyterrell
That worked. And I can live with that ;-)
Thanks Dave.
