naming playlists
Rollieo
naming playlists
Post by Rollieo »
Hi:
I love your program!
However I can't seem to name playlists.
I choose "new playlist" and right click it to name it and just get the "get info" choice which takes me nowhere.
I have already loaded many CD=g into the playlists with each disc showing up as a new playlist, what I want to do is put all the SGB together in a playlist titled "SGB" and all the Idol Makers in it's own playlist etc.
If I get this worked out and name some playlists can I drag and drop the individual Cdg playlists into the new "SGB" playlist or do I have to re-rip?
thanks
Tim
Re: naming playlists
Post by Tim »
Hello,
If I'm reading your question correctly, you shouldn't be using the right click. Just click on it and you should be able to type in the box naming it whatever you'd like. Then just "select all" of the brand and drag it to the newly named playlist. Hope this helps.
Tim
to rename a playlist, you select it, then don't move the mouse and click again. or press return/enter.
you can not drop a playlist INTO a playlist, but you can drop SONGS into a playlist, that's rather the point!
Rollieo
Post by Rollieo »
The problem was just that when I single clicked nothing happened for a couple of seconds so I would click again or double click and get no where.
It is working now it just takes 2-4 seconds so respond and open the typing window.
Thanks again
R.
after the playlist is selected, click again and don't move your mouse, the delay time is 1 second.
