Won't pull meta data
acesfull145
Post by acesfull145 »
I have 400 mp3+g files. I added 10 of them to my library yet only 4 I can actually play. The other 6 seem like they can't find the meta data. I left click and hit "pull meta data" the window comes up like its loading but nothing happens. Is this a common problem? Is there just not data for some songs?
Re: Won't pull meta data
ID3 tags are NOT written for karaoke songs by just about all other software i've ever seen. the only one that does it consistently is kJams.
so if you got your songs from somewhere OTHER THAN kJams, then they're not likely to have any data in the tags.
if the data is in the file name or the folder structure, you can glean it out using Reinterpret Names.
