Video frozen on playback from CD-G / KJ Pro Code enter twice
goateeguy
Post by goateeguy »
On the newest version... (2 issues) [However issue 1 happened on the older version, issue 2 appears to be new]
I stick in a disc, it loads up, asks me for the KJ Pro Code...
I type it in... Window disappears...
few seconds later it appears again...
I type it in again and it works.
(This issue seems to be intermittent but often) [I"m using the latest mac version, on 10.7.2, ALSO I have look up using all other services turned off, just KJ Pro is on.]
second issue is this...
after it gives me the track info... I double click a song just to make sure YES it did grab the right info... it seems most of the time now it freezes about 5 seconds in. (JUST the video) the audio keeps playing... however the progress bar at the top freezes as well. \
If I hit stop, and play the song again, it works. This seems to be only for a newly inserted disc.
Re: Video frozen on playback from CD-G / KJ Pro Code enter t
I am not seeing these symptoms! Please get me on iChat so i can see this problem.
Note: first confirm that you can reproduce the problem, what often happens is we finally get on iChat then the problem can't be reproduced!
https://karaoke.kjams.com/wiki/IChat/Mac
