Latest update broke kJams
tenjin
Post by tenjin »
Hi,
I just tried to install the latest auto update and now kJams crashes when it first runs.
The error I got was related to com.rosecrux and looks like a memory fault?
Can you advise how I can completely uninstall kJams so I can try installing it again please? I've deleted the app, ~/Library/Preferences/com.kjams.* and ~/Library/Application Support/kJams etc. but I still get an error and crash when I run it.
Any tips you can give would be very much appreciated as I am running an event with kJams on Friday!
I'm running kJams Pro on Mac OS X 10.6.
Darren.
Re: Latest update broke kJams
re-download, it's fixed. uninstalling usually does nothing except waste your time.
Lshiny
Post by Lshiny »
Still no joy on the Windows version.
And I haven't been able to get the prior version to work after re-install.
Also when it crashes, the error reports won't send:
Your message did not reach some or all of the intended recipients.
Subject: Crash Report (Win) kJams Pro 1.0d52r24
Sent: 10/13/2011 2:04 PM
The following recipient(s) could not be reached:
'[email protected]' on 10/13/2011 2:04 PM
None of your e-mail accounts could send to this recipient.
send me the crash report manually:
https://karaoke.kjams.com/wiki/Logs
then: try the rogue build
https://karaoke.kjams.com/wiki/Downloads/Rogues
please let me know if it DOES work!!
Lshiny
Post by Lshiny »
I didn't gets chance to try the rogue build before the r25 release, which fixed the problem.
Whew! A bit rocky there but now should be smooth sailing!
