Need help all around
acesfull145
I've download the program and I have a whole bunch of mp3+g files (separated into mp3 and cdg) how do I combine them so that I can put into iTunes? Also when putting files into my kjams library (both cdg and mp3, named exactly the same) they do not play on my computer. It searches for metadata then times out. Any help is appreciated. Thanks...and I'm on a mac btw
Re: Need help all around
you don't put them into iTunes. if iTunes could play your CDG files, there would be no point to kJams.
what do you mean "It searches for metadata then times out"? do you mean "i see the 'pull meta data' task in the activity window, but part way thru it hangs and never completes" ?
if it never completes, then how do you know if they do not play on your computer?
if that's NOT what you're taking about, then what do you mean by "they do not play on my computer" ?
