search
texwire
search
Post by texwire »
is there a setting so that you can search as you type,in other words in the library when you are searching for allan jackson he will show in the bottom as you type like ala will already show him and others.
Re: search
the search engine is not fast enough for that at the moment.
https://karaoke.kjams.com/wiki/Slow_Searching
you CAN turn it on in the secret prefs if you don't have that many songs, but if you have problems, you're on your own.
https://karaoke.kjams.com/wiki/Secret_Prefs
"Update search results while typing"
