Dave, I've emailed you a bug report because I had an error using the Mantis site.
I had to send you some sample files related to an importing bug from CAVS.
Please confirm that you got the emails. Thanks!
Bug reports
Re: Bug reports
for those interested: there's an issue of importing CAVS files where the ID of the file is ending up in the "track number" field. but the "track" is a "short integer" so it "wraps" at 32767, so the next number "up" from that is -32768.
i think the problem is on the import, using file names instead of using meta. but i have to see how he's doing it.
Re: Bug reports
By the way when we did the import, kJams didn't ask whether to use filenames or metadata. It just started importing.
Re: Bug reports
check your prefs->tags->reading. should be set to "use tags"
Re: Bug reports
I think I have seen this too.
Re: Bug reports
bug is fixed now in the mac rogue, will be fixed in the next release
Re: Bug reports
I just want to publicly say "Thanks" to Dave for his awesome support!
