Transfer from Mac to PC
leydigital
Post by leydigital »
I know this is brand new for the PC, but I want to test er out. I spent weeks cleaning my library on the mac when I first got kjams. I want to move everything from my Mac to the PC (windows7). I will be using the same hard drive. Will it still have to pull the Meta Data, etc?
Re: Transfer from Mac to PC
yes it will. although the file format is the same on both, i'd recommend against trying to move your "kJams Library" folder, because kJams at present has no facility to edit "search paths" (the locations where it will find your song files). So at this time, you should just do "add to library" and re-add all your music. then kJams will "pull meta" automatically.
