USB or Firewire external hard drive
chuckster
Post by chuckster »
What is the better choice? Will USB have lag at all... I don't think you would get lag with firewire! I would love to hear some feedback as to who is using what one and the success or failure with it!!
Re: USB or Firewire external hard drive
i go firewire every time
chuckster
Post by chuckster »
Will USB create LAG even for home use?
no, nothing should create lag, because everything is always pre-cached. any lag is a bug.
chuckster
Post by chuckster »
Ok, so I could actually get by with using a USB drive since they do cost quite a bit less.
yes you can. i can't stand them myself.
Einsteindork
Post by Einsteindork »
I have been using external drives for almost 6 years in my home system. I will never use a USB again. I've gone through 4 before I decided to go Firewire. It's still kicking and I have seen no problem yet. It's definately worth the money to avoid USB at all cost when it comes to external HD's. In my humble opinion. :)
yep
If anyone cares, you can often find cheap firewire externals on Buy.Com or eCost. I got my current 320 Gb external FW800 drive for under $50
