Combining Multiple Libraries
rmanke
Post by rmanke »
Hello,
A friend of mine has multiple kJams libraries, because he was importing from several CAVS units and wanted to keep them separate.
Is there a way to combine them, or have them appear as separate libraries in kJams?
(I noticed one other question related to this in the forum, and it was from 2006 so I thought I would ask this somewhat similar question again).
Thanks for any suggestions.
P.S. I am fairly technical, and could figure out how to merge XML files, if that helps.
Re: Combining Multiple Libraries
no, there's no way.
you have to just start from scratch and "add to library" all the songs you want.
rmanke
Post by rmanke »
Ok, thanks for the quick response.
Ron
