Warning when power is disconnected & on program quit.
Club Ample
Post by Club Ample »
I would like to see an indicator of battery life when the power cord is disconnected....and flash a little warning icon to get your attention . Just something to guard against the computer shutting down mid set in case you forget to plug in your laptop.
The other feature i would like to see is an "Are you sure you want to quit kjams?" upon pressing the apple + Q.. even something as short as "Exit?" would be sufficient. Just to prevent an accidental shutdown of the program while in mid set.
Re: Warning when power is disconnected & on program quit.
battery indicator:
you can get any number of 3rd party apps for that
for "warn on quit":
you can turn on "Warn if current song will be interrupted", so if you're playing a playlist (even the Rotation), then you'll always get a warning when you try to quit.
When this has happened to me I got a message on the screen saying the computer is about to go to sleep to protect the memory (Or something like that) I've then plugged the power lead in the it's been OK, but once it happened and I went to get the power lead and I'd not taken it with me so I shut everything down except kJams and then I prayed, My prayer was heard and I finished the show without a shut down. The power lasted a further 1/2 hour but the laptop was only 12 months old, I don't know how long an older battery would last.
The last time it happened I wasn't at the computer and I heard a warning sound through the speakers and want back to the computer and there was the message.
Club Ample
OK I see what you mean with stop music option.. that works. 8)
The battery indicator...I can live without it.. its just a nice thing to have things in place to help guard against a train wreck at a live gig.
there are some terrific third party tools that can put a very big meter up showing you your battery level :)
