DAT files
DAT files
I've come across some video CD's that I couldn't rip to kJams when I first started using it. When I look at the disc on the computer the files are DAT files. They're video CD's. Is there a way to use these on kJams yet
Re: DAT files
you must use VCD & MPEG Tools to rip them to m4v
as explained here
Re: DAT files
VCD & MPEG Tools Works great on some of the disc but not all. On some of the Sunfly VCD's I can only get the menu tracks to convert and the karaoke tracks only convert to AVSEQ04.MPG
Is there another way to do this
Re: DAT files
not sure what you mean that the track "only" converts to an mpg file? isn't that the goal here?
Re: DAT files
Sorry I didn't explane that well at all. It's as though the tracks don't convert fully
This is what I get
unplayable mpg's.jpg (18.59 KiB) Viewed 3977 times
Re: DAT files
hmm, weird! you'll have to get tech support from the guy that wrote that.
also try http://www.moviesmac.com/video-converter-mac/
