MacBook Pro Microphone Question
shookri
Post by shookri »
Ok I need some help here. I can't get my Mic sound out to my TV.
I have a new MacBook Pro. It has Video and Audio out via the mini-display port(MDS). It also has audio in via the line-in port.
Everything hooks up fine. The Mic is a Nady wireless kit that plugs in directly to the line in jack. It VU meter registers in the system preference's sound panel.
Kjams plays perfectly via the MDS adapter. Just the Mic is not playing out or on the macbook pro.
Any ideas why the Mic is not blending in?
Kjams Rocks!
Re: MacBook Pro Microphone Question
you have to select it in the kJams audio preferences
but frankly i recommend you use GarageBand or Audio Hijack. Much better, plus effects!
http://karaoke.kjams.com/wiki/Microphone
