kJams/AVI curious
franks
kJams/AVI curious
Post by franks »
I notice a number of "portable" karaoke microphones have hit the market.
The mics featured are self contained in that they use SD cards for their AVI karaoke files. The mics have active vol, echo, & pitch control. Also they state that they provide S/W to convert CDG files to AVI files to load the SD card.
Curious to know if kJams library files can be converted to the AVI format so that they can be used in such a mic system and if so how?
Any enlightenment?
Re: kJams/AVI curious
kJams can export to any format supported by QuickTime. If there is a QT exporter for AVI, then go for it.
But AVI was introduced in 1992, and it's pretty lame, so i'm not going out of my way to make that work unless i get LOTs of requests for it. :)
Update: Well gosh, looks like kJams fully supports AVI for import and export!
franks
Post by franks »
I'm not sure if I can follow you.
I don't see any menu option to export a kJams file as an AVI file.
Although I can export to QuikTime as MPEG-4 file.
sorry, QT Export is a Pro only feature. Lite version can export to like iPhone and stuff.
to get AVI with kJams Pro, install Perian.
then go to prefs->exporting and set your encoder to AVI
franks
Post by franks »
OK Dave
Yes now I see!
YAY!
