New kJams SoundFX player
If you want to be able to play sound effects while using kJams, head on over to the code site to get the player I wrote:
https://karaoke.kjams.com/wiki/Code/new ... cts_Player
Re: New kJams SoundFX player
This is pretty kewl , Nice job! My friends got a laugh from the applause sound fx i copied from ilife. Do you know iof any good plaes to download kewl sound FX, or maybe some tv theme songs?
Would it be possible to have a sound fx play automatically at the end of a song? Or maybe be able to set it to play 4 seconds before the song ends? Just a thought!
I just did a search for "sound effects" and found pages of sites with free files for download.
I could do those features you want, but I'd have to figure out a UI that will work for letting the script know what your intentions are. There is also the problem that no songs end the same way, some have a long silence at the end, etc., so it will be hard to accurately time the effect. But I will give it some thought.
Note: one easy way to have a sound play at the end of a song is just to make a dummy singer (I call mine *interlude) that I put my sound files into. I then drag it around in the rotation to play as needed.
Last edited by DeusExMachina on Wed Apr 06, 2011 11:21 am, edited 1 time in total.
:shock:
