Slightly improved "Song Added" alert for kJams Server
Often times when using kJams Server, the user will miss the "Song Added" and other status alerts at the bottom of the window. (Heck, even I just recently noticed it!) As a result, they will mistakenly hit the "Tonight" button over and over, thus adding the song multiple times. To combat this (but not be quite as intrusive as a pop up alert) I made this little code snippet that will make the text bright red and flash it several times to catch the users attention.
(I am going to do some psychological experimentation tonight to see how effective it is.)
Hope someone finds it useful.
Find it here:
https://karaoke.kjams.com/wiki/Server/C ... to_main.js
Re: Slightly improved "Song Added" alert for kJams Server
meanwhile, i'll take that as a bug report and fix the "bug" of being able to add the same song more than once to a "tonight" list.
Well then, as an added "bug report", I often get multiple copies of a singer because of the latency between submitting the new singer form and the actual creation of said singer. When it is not fast enough, the user interprets this as an interface failure, and hits the submit button again (and again (and again (and again)) the record being 18 times (thus far!))
Not sure what the best solution to this is though. Ultimately it should be server-side, but maybe a little client-side code can form a stop-gap.
gotcha
