Newest Windows Version crashing before even opening
kjb87
Post by kjb87 »
I have the lasted update of the windows version of kjams and it keeps crashing before opening. i tried to repair it and it still won't open. i'd try to remove and reload but i'm concerned that'll get rid of my library and i'll have to start from scratch. if i open the installer choose remove, and then try to reinstall will i have to redo the library?? If so is there an update comming soon that'll work??
Re: Newest Windows Version crashing before even opening
zip and send me your "kJams Library" folder
