Persistant songs
Persistant songs
It would be very useful, and would streamline things for a lot of users and their singers if Tonight lists could have tracks set to be persistent. By this I mean they stay in tonight by being added every time they are marked as here. For regulars that always sing the same tracks, this makes setting them up much simpler. By making this part of the "Mark as here" routine, you avoid all the troubles of having the songs recurring over and over in the same night. This could easily be done, I suspect, by adding an invisible playlist to a singer, whose songs are copied to tonight when they are marked as here.
Re: Persistant songs
it's an interesting idea. more likely i'd add a new meta data column "always add when marked here" or something. but it seems kindof specialty-ish. i'll add it to the list but not for 1.0
Not sure how specialty-ish it is. I suspect a lot of people have regulars who always request the same songs, or just come in and sit down, knowing that when you see them, you'll do it for them. Might be wrong though.
Einsteindork
Post by Einsteindork »
Your not wrong DeusExMachina. That's exactly how my shows go. I see them come in and they know I will call them in the order they got there. Since they know that their favorites are already saved for them they just tell me to pick a song from the list unless they already have a new song in mind.
k, well it's on the list :)
Imagine doing this with another karaoke program. I do as is described in this thread and what often happens is the singer comes to sing and says "I want to sing another song first" all I need to do is click the drop down and click the song they want and the track plays instantly. I wonder if Dave knew just how useful some of the features he's built in would be.
I particularly appreciate things like this when I see other DJ's struggle and curse a singer for changing their mind.
Also, long that same vein, Dave, don't forget my feature request to populate the current song drop down with contents of "Favorites" followed be "History". Settable as a pref. Should be relatively easy.
on
the
list
