TunePrompter isn't compatible with Snow Leopard
I've just had this email
Sorry for the trouble. The TunePrompter software isn't compatible with Snow Leopard at this time and I don't know of any plans on updating it
Re: TunePrompter isn't compatible with Snow Leopard
i've been running it all this time on Snow Leopard with no problems. what problem are you seeing?
When I export to Quicktime it crashes most of the time.
don't export to quicktime silly
let kjams do that!
When I export for Apple TV it crashes and when I export for ipod/iphone the words are minuscule
what is "it"? are you still talking about TunePrompter?
Yes. TunePrompter crashes when I click Create Video. The only time TunePrompter doesn't crash is when I have export for ipod/iphone selected and then the words are silly small
my first reply (okay first one when i knew what you meant) said "don't export to quicktime" from TunePrompter. maybe the "from TunePrompter" wasn't clear. I'll try again:
Don't export to QuickTime using TunePrompter.
let kJams do that. in other words: bring your TunePrompter file directly into kJams, and use kJams to export to QuickTime.
then again, if all you want to do is play it in kJams anyway there is no need to go to QuickTime at all.
I see
I thought I had to click create video and then I would have the karaoke track. So, if I make the track and save it then import the resulting .ktp into kJams It'll play.
yes that's the point. you can also edit the track in kJams using Producer
Thanks. It works
jfbiii
Post by jfbiii »
HAHA...seriously? I either didn't know or didn't remember that kJams could just use the KTP file. I dug up an older mac and exported from TunePrompter. *doh*
right. do NOT export from TunePrompter. just save the KTP file, quit, then drag it into kJams.
note: don't forget to set meta data while you're in TunePrompter.
Thats how i create my CDG's (as a ktp)
So, if i want to save a ktp and burn it to CD can i use the export to quicktime?
