Disable esc button
Disable esc button
I think I know the answer but I'll ask anyway.
Is there a way to disable esc button whilst kJams is playing. I've twice had tracks stop playing (Stop not pause) because I've inadvertently pressed the esc button, or I should say somethings touched it firm enough to stop the track playing. The first time it happened I had no idea what caused the track to stop but It happened again last night so now I know.
Re: Disable esc button
no, currently there is no way to disable the escape key. :(
