when i search for songs within kjams ... it takes anywhere from 5 seconds at a minimum .. to sometimes more than 10 seconds before the available songs show up....
i remember reading something about how kjams actually searches...and i cant remember where.
when i use pc programs to do karaoke i dont have that same issue... i tried karaoki pcdj demo and the search was almost instant.
other dj programs i use such as serato and virtual dj as you type in the letters it narrows down the files that could match
that makes it really easy and fast because you only have to type as much as you need to find the file , sometimes you can get away with only 4 or 5 letters before the song you want comes up...
any help on this would be appreciated
by the way dave... i do want to say the kjams program has worked for me at every gig ive used it... without fail.. no crashes...which is more important to me than quick searches... but quick searches would be nice
