Importing after Consolidation
I have consolidated my entire library like your instructions said, so the songs are more organized. Now I am wondering how to import any new songs I add, so they will reside with the rest of the kJams songs and not in a separate folder.
Re: Importing after Consolidation
consolidating is a once-only thing. if you obtain new files without using kJams (that is, you get them WITHOUT using the built in music stores or without ripping them), then you have to consolidate again. but only if you really care about keeping the files organized. kJams doesn't care if the files aren't organized.
