I'm usually pretty savy.....but........
jfp187
Post by jfp187 »
I've owned the full version of kJams for about a year or so and love it. In the last month or so I started getting error warnings about moving "AtomicParsley" into the folder "kJams Plugins":AccessDenied, insufficient access privileges for operation....followed by .....There was an error moving "Burner.bundle" into the folder "kJams Plugins":afpAccessDenied, insufficient access privileges for operation. I tried using the solution posted by finding every kJams folder and ensuring read and write permissions were ok....no luck. I then deleted the plugins folder. No luck. I then tried re-installing kJams. No luck. I then tried re-installing the burner plugin. Again no luck. Nothing changed in the way I have had the software installed and suddenly every time I launch the program, import a cd or burn a cd I get these warnings on each and every song imported or attempt to burn. HELP....I surrender to a higher authority on this one. :-)
Re: I'm usually pretty savy.....but........
