Lost letters when burning
Dwartz Farquhartz
Post by Dwartz Farquhartz »
I made my first Producer video and some letters in words are missing. I purchased kJams after making the video, but before burning - could that be the problem?
I did get the following error message about 20 times.
Re: Lost letters when burning
latest version of kJams?
send me your ktp file and audio file.
when, exactly, did you get the error message?
Dwartz Farquhartz
Latest version of kJams, check.
I got the message when importing the ktp, iirc.
I note that when I reopen the ktp with tuneprompter, it's all jazzed up. Perhaps that's normal.
files emailed to your kJams email.
Define "jazzed up"
Dwartz Farquhartz
The line breaks are all gone.
i got your file and tried it and it worked perfectly first time. i see no problem at all with it.
please tell me exactly what version of kJams you are using.
Dwartz Farquhartz
1.0d51r31
I burned a 2nd disc and the same letters are missing. There are not even spaces where the letters should be. The song plays flawlessly before the burn. It's just the burned copies that are the issue - I didn't make that clear in my original post.
If you have my file, the "s" in borders on the fist page, and the "c" in traffic on the 2nd page. There are more later in the song.
Could this be a font issue? I'll change the font and retweak if that's it - the font I chose doesn't look great anyway.
Dwartz Farquhartz
I started from scratch, because I didn't like the font anyway. No errors when importing, no problems with the final product, burned or otherwise. The ktp file looks ok when re-opening as well.
Sorry if I wasted your time.
no, no problem at all, but i'd sure like to know what happened so i can fix the bug, so nobody will ever have the problem you had. if you can reproduce it, then show me how to reproduce it, that would be swell.
