Fill in music
Sidsky
Fill in music
Post by Sidsky »
Hi Dave....
I just completed my "Karaoke Kave" in my house. I found kjams and have installed it... Wow! you have done a great job! I want to purchase the full version, but have a question... Is there a way to have kjams play fill in music between songs automatically? I am running windows 7.
Re: Fill in music
kJams doesn't play music between karaoke tracks but I believe it's on his To Do List. I don't know how far away this is, but, I use a short cut I created with Quickeys to stop and start iTunes.
Re: Fill in music
currently no but it is the highest priority *major feature* on the to-do list. I will get back to this list AFTER i've finished the Windows version (which is when it has full feature parity with the Mac version). You can track my progress on that by watching the changes made to this page
meanwhile, you can take a look at the Crossfade Script
if you have questions about the script, please post here, rather than send an email, so the author of the script can reply (who is not me)
Sidsky
Re: Fill in music
Post by Sidsky »
Thank you for the response... (both Len & Dave)
Another question.. I want to use the program in a sort of basic way. I am just using it for my own entertainment and that of my family.
I want to be able to play songs, but as they are playing drag other song into the Que so they will start when they playing song is finished.
This seems pretty basic, however once i drag another song into the que it starts to play immediately and cuts out the existing song. What am I doing wrong?
Also I cant find a way to delete songs from the window after I have dragged them there. Help!!!
Re: Fill in music
what do you mean by "Que", do you mean "playlist" or do you mean "singer's tonight list" or what?
where are you dragging FROM? are you dragging from Explorer? or are you dragging from within kJams (like from the Library playlist?)
if you're dragging from Explorer, you're doing it wrong. you're supposed to load up all your music into kJams, and then use them from there.
otherwise this may just be a bug. but i need to know more clearly what you're talking about.
what "window" are you wanting to delete songs from? i think you mean "playlist" ? right?
to delete a song from a playlist, you select it and press delete (or backspace)
