Add To Playlist
kenwardc
Add To Playlist
Post by kenwardc »
Hi there
I'm new here having just purchased KjamsPro so please be gentle! ;)
Firstly have to say - the software is OUTSTANDING. Thanks so much for putting so much effort into it.
My feature request - as it looks and behaves so much like iTunes, what would be great, especially when dealing with large lists of songs, would be to be able to right-click and say "Add to Playlist", at which point a selection of playlists would come up. I guess one would have to create the playlist first but it would just be a slick feature for an already very slick bit of software.
Cheers
Chris
Re: Add To Playlist
hmm yes i've done that for Singers in the Pro version. you can right click and add to a new or existing singer. i'll add "playlists" to the list of "todo"
kenwardc
Re: Add To Playlist
Post by kenwardc »
Thanks. Yes - I have the Pro version and that was the thought - if we can do it for singers.... ;)
Cheers
Chris
Re: Add To Playlist
leo-magic
Re: Add To Playlist
Post by leo-magic »
The ability to move Songs from the store to a Playlist would be great too!
Thanks!!
Léo
Re: Add To Playlist
well you can drag and drop for that. and/or you can target mode for that. i think.
leo-magic
Re: Add To Playlist
Post by leo-magic »
for me that works only on singers. (drag an drop to playlist does NOT work from the store...)
Re: Add To Playlist
Confirmed. Drag and drop to a singer works fine, but drag and drop to a playlist fails to highlight the target, and instead releasing the song over the playlist just cancels the process.
However, if you set a playlist in target mode, double clicking on the song in the Music Store DOES add it to the play list.
So 50/50?
Re: Add To Playlist
bug, thankz
leo-magic
Re: Add To Playlist
Post by leo-magic »
Are you planing to fix this or not?
Leo
Re: Add To Playlist
dragging a non-streaming song from a Store to a Playlist should cause a purchase. it's on my list, so yes i plan to fix it. but it's not at the top of the list
