play lists
kellieburke
play lists
Post by kellieburke »
can you use your ipad touch for the audience to search the playlist to choose?
Re: play lists
i am not sure what you are asking. you can search the Library only, right now. then you can add a song you find to your "tonight" or "favorites" list. you can also browse your "favorites", or "history", and add any of them to "tonight", and you can browse your "tonight" and drag-reorder them to set your song order.
