Assert Fail error.
jacksaturn
Assert Fail error.
Post by jacksaturn »
Dave,
Not sure what I did to cause this problem. I am working in Producer and when the "Converting Media Stream" status bar shows up, I get this error:
Assert Fail: curP != i_gwP, in file: '/Users/davec/
Developer/depot/kJams/Development/ source/
Music/../../ source/Utils/CPixels.cpp' at line 671
If I repeatedly click "OK" in the error box, the "Converting Media Stream" status bar will continue to increment, and eventually I can get the error window to disappear without needing to Force Quit.
Jack
Re: Assert Fail error.
can you provide a little more info?
when does the converting dialog show up? are you already in producer? or when you just start? or did you do something like "get media info" or how exactly do i get this to happen?
jacksaturn
Dave,
Sorry, I didn't know how it happened before, but now I've figured it out.
You had advised me on how to change fonts in Producer by using "Get Media Info." The error happens when the CDG is being recompiled after I've changed the font or font size.
Jack
good to know thanks, i'll try to get that fixed for tonight's build
i have tried to reproduce the problem but i am unable to :( so i can not fix the bug.
can you reproduce this problem with 100% reliability? if so, zip and send me the song you're working on (all assets) and i'll try to repro it with your file.
