Kjams on the move ...
ChurchCat
Post by ChurchCat »
Forgive me if this is a bit of a noddy question but is there any reason why I can't install Kjams onto a keyring type USB drive? I would quite like to keep the ripped CDG data on more than one computer and move the application together with the lists of singers, their "tonight" lists, venues etc. on a USB stick.
Is there any reason why I should not do this?
CC
allowed licenses
yes you're allowed to activate your serial number (license) on two computers that you own. No, you can't just move from one computer to another easily, that would require me to deactivate an activated machine. it would be handy if eSellerate would let the user manage activations themselves, but they don't, currently it requires that i get involved.
if it's only two computers (that you own) that you want to move between, then yes, no problem, just install it on both machines, using the same serial number. if you need more machines, you need more licenses.
http://www.kjams.com/wiki/Moving
ChurchCat
Post by ChurchCat »
o.k. ...
How about if I keep the data on a separate drive. The singers, venues etc. Can I do that or not?
Oh, just out of interest I have ordered a plextor external drive today. Once I can get it working I will be buying kJams pro. It does look a fine bit of software.
CC
didja read it?
The answer is in the link i sent:
Short answer: yes
ChurchCat
Re: didja read it?
Post by ChurchCat »
Short answer: yes
Sorry Dave, I missed the link in the previous post.
:oops:
Once again thanks for your help.
CC
