Hello all and some help if possible :)
jmorrone
Post by jmorrone »
I'm brand new to this board and I would like to purchase the KJams software however I need to know exactly which items i need to get for my needs. All I would like to do is to take the existing CD+G files from discs or my harddrive and then pick a few songs from each and burn them onto a CD i can take with me to different karaoke shows to give to the dj to use instead of the songs he has.. Which pieces for the mac do i need to buy?
~James
Re: Hello all and some help if possible :)
You need kJams Lite, and the Burning plugin. total $80 :D (note: Burner is not yet finished for Windows)
jmorrone
Post by jmorrone »
I have a matshita (spelling) that is built into my IMAC. If I buy KJAMS and the Burning Plugin will this make that drive work, or do I have to buy a separate external mac drive as well?
no
the tryout version is perfectly capable of ripping and burning. ('twould be silly to offer "shareware" that could not perform such a critical function for evaluation!)
so: if you can rip/burn with the tryout, you can rip/burn with the paid. if you can NOT rip/burn with the tryout, you can NOT rip/burn with the paid.
please see:
http://karaoke.kjams.com/wiki/Compatible_Drives
