Combining Libraries
cohnhead
Combining Libraries
Post by cohnhead »
I recently cleared my whole library of songs, but kept a copy of the Library.xml file, the Playlists folder, and the Songs.ktd file. I then added all new files to a new library. Is there any way to combine those 2 libraries?
nope
not at this time.
you'll just have to "add to library" the other files, but you've lost all your meta info editing.
better to start with your old library and "add to library" the new files
