"converting kma file failed"
paul hewett
Post by paul hewett »
adding to my library from external hard drive. i have a lot of kma files that are showing up in the library that will not play and i get the notice that
"converting kma file failed". is there a fix for this?
thanks for any help on this.
Re: "converting kma file failed"
send me a kma file that fails.
mac or windows?
if mac, do you have Flip4Mac installed?
Meerkat
Post by Meerkat »
Please excuse the thread necromancy, but I am having the same issue and was wondering if a solution was ever found to this problem?
I'm running KJams Lite on Mac OSX 10.11.6. And I do have Flip4Mac installed.
Many thanks
Rob
i don't remember what happened.
send me the kma file :)
Meerkat
Post by Meerkat »
Hi Dave
Thanks for the reply and sorry for the delay. I will locate some files that don't work and forward them to you.
Rob
