VGA cable to my monitor
chasiyana
Post by chasiyana »
how to convert vga signal from a computer to a coaxial cable signal to get computer screen in a tv? tv's input is carried through coaxial cable and the out put from the computer is taken way by the vga cable. so i like to know how to convert the vga signal to coaxial signal to get an out into the tv i.e to get my computer screen display on my tv?
__________________________
external keyword tool ~ keyworddiscovery.com ~ keycompete.com ~ compete.com ~ webmasterworld.com
gsteffens
Re: VGA cable to my monitor
Post by gsteffens »
I'm certainly not the best advisor on this topic but if your TV only has a coaxial input then I think you will need a VGA converter to get the VGA signal to RCA and then an RF modulator to go from RCA to Coaxial. That setup will likely cost you around $100 so you may want to consider buying a used TV with more inputs (RCA or S-Video) and drop the RF modulator. I bought this VGA converter from Monoprice which works well for VGA to TV with either S-Video or RCA.
what he said.
Nah, it's cheaper than that. You can get an RF modulator at Best Buy or RadioShack for around $35, and a VGA - S-Video adaptor for about $5-$10
Or you can get them even cheaper on eBay.
Most TVs should have an RCA composite input, so you might be able to just get by with the adaptor.
yeah. that.
