kJams Pro 10.d51r3 Crashes when playing CAVS disc
olsonea
Post by olsonea »
Below are two of the logfiles that were created when KJams crashes. I tried emailing the error report, but the email got bounced back. I also got an error signing up for the Mantis bug reporter tool. This is my last recourse.
So, I just installed the trial version of kJams Pro to test it out. I am try to play a CAVS SCDG disc, which is loaded in my DVD drive. The songs work fine on another player I have. The disc contents are displayed correctly in kJams as well. But when I go play a song, the app crashes, and I am prompted to send the error report. Anyone had similar experiences?
OS: Windows 7 x64.
loading library: -1
### Error not found in cache: -43
Type: <CFURL>, Value: <<CFURL 06CB9148 [100C351C]>{type = 2, string = \\?\C:\Users\eric.olson\AppData\Local\Temp\kJams Temp\300075820936\Library.xml, base = (null)}>
Type: <CFURL>, Value: <<CFURL 065B9080 [100C351C]>{type = 2, string = \\?\C:\Users\eric.olson\AppData\Local\Temp\kJams Temp\300075820995\kJams X Preferences.plist, base = (null)}>
Type: <CFURL>, Value: <<CFURL 06CB9238 [100C351C]>{type = 2, string = \\?\C:\Users\eric.olson\AppData\Local\Temp\kJams Temp\300075821306\Rotation.xml, base = (null)}>
Type: <CFURL>, Value: <<CFURL 020CCE18 [100C351C]>{type = 2, string = \\?\C:\Users\eric.olson\AppData\Local\Temp\kJams Temp\300075821308\KJ Rotation.xml, base = (null)}>
Type: <CFURL>, Value: <<CFURL 05A1CF58 [100C351C]>{type = 2, string = \\?\C:\Users\eric.olson\AppData\Local\Temp\kJams Temp\300075821313\Singers.xml, base = (null)}>
Type: <CFURL>, Value: <<CFURL 06E23890 [100C351C]>{type = 2, string = \\?\C:\Users\eric.olson\AppData\Local\Temp\kJams Temp\300075821370\SCdg_64023730_910.xml, base = (null)}>
Success opening file spool
Type: <CFURL>, Value: <<CFURL 0592B860 [100C351C]>{type = 2, string = \\?\C:\Users\eric.olson\AppData\Local\Temp\kJams Temp\300076847509\kJams X Preferences.plist, base = (null)}>
Type: <CFURL>, Value: <<CFURL 020CCEB8 [100C351C]>{type = 2, string = \\?\C:\Users\eric.olson\AppData\Local\Temp\kJams Temp\300076848339\CD 6d0ab309, base = (null)}>
deleting deq
i_err closing file spool: -27
i_err closing file spool: -128
success opening QuickTime spool
Re: kJams Pro 10.d51r3 Crashes when playing CAVS disc
I have fixed a crashing bug related to playing CAVS discs. there will be a new release r4 today sometime.
