quitting...
timothyduggan
quitting...
Post by timothyduggan »
Hi,
I downloaded Kjams Lite, bought a song from TriceraSoft, tried to add it to the library and the application quits. Every time.
Also happens in the pro version. Do I have to rename this file or what?
-Tim
Re: quitting...
If you buy a song from the built-in TriceraSoft store, then you do NOT add it to the library. That all happens automatically. if you're crashing, send me the crash report.
timothyduggan
Re: quitting...
I can only send the report to Apple...
I cannot cut and paste it either
-Tim
Re: quitting...
cancel the one to apple
next time you run kJams it will ask you to send the report to me
