Trouble editing key commands
dizzidecazz
Post by dizzidecazz »
Hi,
I tried to reassign key commands for song slipping. I want to use apple-left/right arrows. I opened and editied the keyboard.txt file as per instruction.
here's what i changed the commands to:
"Menu/Controls/Song Slip Back" = "a-0x64";
"Menu/Controls/Song Slip Forward" = "a-0x65";
"Menu/Controls/Song No Slip" = "ca-0x64";
I relaunched kJams but alas, they don't work and neither do the default keys.
btw: I'm using a MacBook Pro, not a full keyboard.
Any help is appreciated
Diz
Re: Trouble editing key commands
delete the key shortucts file, then re-run with the LATEST version. THEN edit it and change these:
"SubMenu/Sync-Slipping/Song Slip Back" = "a-0x64";
"SubMenu/Sync-Slipping/Song Slip Forward" = "a-0x65";
"SubMenu/Sync-Slipping/Song No Slip" = "ca-0x64";
note: there's already entries for these, make sure you replace them
dizzidecazz
Success!!
Thanks Dave.
