We have a large library, when typing in an artist's name - from an i-pod, using i-jams search - a message pops up, 'ERROR' The search results were too large. Try narrowing your search'. Example; I tried typing Reba, McEntire and Reba McEntire the same message came up each time. Is there any way around this?
Thanks,
Paul
ijams searches
Re: ijams searches
you apparently have more than 200 "reba mcentire" songs. try narrowing your searching. ie: type MORE search terms
paul hewett
Re: ijams searches
yes,
i have a large library. over 52000, with no duplicates. trying to help customers who use ijams and want to view all of a specific artist songs. other than this not working, ijams works great.
thanks, paul hewett
thanks, paul hewett
Re: ijams searches
well, there is a secret pref where you an allow arbitrarily large search results lists, just note that they may take longer to transmit
you can set it as high as you want<key>Maximum number of items in web search results list</key>
<integer>200</integer>
paul hewett
Re: ijams searches
thanks a million dave. works like a champ. set it to 2000. searches are still fast, takes less than 45 seconds for the largest and thats elvis. thanks again.
paul hewett
paul hewett
Re: ijams searches
gosh, 45 seconds isn't "fast" imho, but hey, if you're happy then yay!
paul hewett
Re: ijams searches
it is more like seven . works fast. very happy. thanks again.
paul hewett
paul hewett
